Truck has good batteries, everything has power, when I go to start I turn the key and it clicks once. Doesn't start. Bad starter? Maybe solenoid? Need opinions fast
try jumping the solenoid behind the pass side battery. I use a big screw driver between the two big terminals. Make sure your truck is in neutral. if that is not try giving the starter a rap with a hammer.
