Heated Seat wiring???
8541 Views 2 Replies 1 Participant Last post by  shiprek
I am replacing my non heated leather bench seats (40/20/40) with heated leather bucket seats and console from a 2002 F250. I have the original wiring connector so connecting properly to the seats is not problem. I also have a wiring diagram that is "almost" exactly what I need. My seats have a "heated seat control module" although I keep seeing mention of a "heated seat relay". Did the module replace the relay at some point? I can not find a "heated seat relay" anywhere. I have also hooked up the heated seats directly to a 12v source per the wiring diagram. (Want to test before I install) With the 12v power source:
1. I do not get a yellow "power light on" when the heated seat control button is pushed although I do get the yellow on light to flash momentarily.
2. The seats to not heat up (since I do not have a power light on I would not expect the seats to heat up).
3. Is the heated seat control module looking for an additional signal (i.e. a seat belt connected) before it will energize? My drawing does not show this but it would make sense.
Any and all help is much appreciated.
Running down wiring but with the heated seat control module, it is a bit difficult:bump:
Update to Heated Seat Wiring
If one of you Ford Techs want to jump in here, feel free. I have my wiring narrowed down to:
wire color:
Dk green-12v supply to power seat adjustment motors(drivers)
Blk/wh-12v supply to power seat adjustment motors (passenger)
Rd/Blk-12v supply to heated seat modules (drivers and passenger)
Lt bl/pk-goes to heated seat module (this varies from my wiring diagram as it shows the lt/pk wire common to both drivers/passengers heated seat modules AND both drivers/passengers control switches, but this is not the case.
Brn/lt. blu-this goes to drivers side seat belt buckle.
Black-Common/12v ground
With power to seat motors, the motors and controls work fine. I still feel that the blu/pk wire and brn/lt. blu wire are key and connected to the seat belt controls somehow. Anyone?? Thx
See less See more
