1 - 9 of 9 Posts
What u talkin bout willis
OK IM THINKING HERE SHORTLY IM GONNA GET A D66 FROM BEANS AND THEN SOME STAGE 2 INJECTORS
MY QUESTION I SDO I NEED STUDS WITH THE D66 AND STAGE 2 STICKS OR AM I GONNA BE GOOD FOR KEEPING THE HEADS CONNECTED TO THE BLOCK
My understanding is the stock gaskets/rods are good to 50 psi. Im not sure though.
I WAS THINKING THAT STAGE 2'S AND A D66 SHOULDNT BE ENOUGH TO MAKE PROBLEMS BUT I WAS JUST WANTING TO ASK JUST IN CASE
WILL THE D66 PUSH OVER 40 WITH STAGE 2'S
Yes it will if your on it really hard. I have the same setup and ive seen my boost guage flutter up to 45psi.
You should be fine if your on stock headgaskets, if the heads have ever been off... Stud it.
Most will hold to 40 psi or so... but some will let go at stock levels!
1 - 9 of 9 Posts
