I am trying to replace the bulb on the driver side of my 2003 PSD. Does anyone knwo the easiest way to remove the housing? Please give me any suggestions you may have. Thanks.
Its a ***** if you remove the headlamp. If you do you need to stick two small screw drivers in the sides to pry those clamps outwards. Then pull up on the clip. I found an L shaped allen key grasped with vicegrips works. Make shift but gets it done. Then theres that hex screw that comes up to adjust it. If you still can't get the bulb in you have to unscrew that (counter clock i think) and the bottom of the headlamp will push out. When you reinstall you have to reaim it with that.
