1 - 9 of 9 Posts
Has any tech tried this test. Pull glow plugs and pressurize coolant system looking for coolant out of glow plugs on the 6.0l?
I always just hooked my pressure tester up to that degas hose on the left side of the degas bottle and pressure tested it.
I hooked up the tester to the degas bottle in place of the cap. I was not trying to read pressure. I wanted to see if head gaskets are bad. when coolant comes out of glow plug holes. It was a fast and easy test.
Here is what I had. I purchased the truck used. Had no smoke because they changed both coolers. Drove truck home and the exhaust had a smell. Coolant pressure never wen't above 2psi as indicated by the degas to gauge and drive test. Purchased a coolant dye test for co2 in coolant. Found the color change of the dye so I remove the glow plugs and pressurized the system to help me comfirm head gaskets. It wouldn't hold pressure as coolant went out glow plugs. Had no boil over or smoke
Discussion Starter · #7 ·
Aretoo if you are looking for coolant leaks, you must suspect something. If so, why drive it without verifying problem.
I do not have any leaks my gaskets are good, confirmed by block-chek and coolant pressure gauge. My reply was in response to you asking anyone if they had done your test. I ws trying to explain to you the danger of testing your head gaskets by pressurizing the system. I didnt want you to pressurize your system and hydro-lock your motor because you have a leak.
Discussion Starter · #9 ·
Aretoo I never had intentions to start it. I do not know what block check you are referring to. I had suspicion that gaskets were gone. I did your other test but pressure never went up passed 2 psi. I just though if you feel as strongly as I did of a gasket problem that the test was the last one for me. The truck is in the yard ready for the tear down.
1 - 9 of 9 Posts
