Well, I pressure tested the coolant system today. T-ed in a mechanical gauge at the coolant return to the degas bottle (Powerstrokehelp.com style) and drove the heck out of it.
Topped out at 8 PSI. When I removed the degas cap to release the pressure the gauge bottomed out at 2 PSI. So I guess PSI is either 6 or 8 max. Either way there was no rapid climb or spike in pressure. Head gaskets are still OK? Good news as far as I can tell.
Oil cooler is on the way out and temp delta was hovering right around 15 while I tested the coolant system pressure. Ran some hills, but no trailer.
UPS just dropped off new oil cooler rebuild kit, intake gaskets, turbo mounting kit, updated oil drain tube, and two green o-rings that for some reason I thought I needed but can't remember where they go.
I'm going to have my mechanic replace the t-30 torx screw on the back of the oil cooler outlet with a hex head that stands proud of of the housing, with anti sieze, so I will be able to remove it for a back flush in the future if necessary. I spend countless hours last week in vain to remove that s.o.b. for a backflush that never got done.
EGR is already deleted and I think I'm gonna gamble on the head gaskets again. Straight up oil cooler swap, labor about $500 and parts were just under $300. Could have been worse.
The wife was near saying that if the head gaskets were out, the truck had to go, or she was. I think divorce might be cheaper than keeping a 6.0 running. For now I'm stuck with this turd (the truck, not the wife). Hope this oil cooler is the last one (it will be number four in 119,000 miles).
