1 - 5 of 5 Posts
I have been studing the water meth injection for some time now reading everything I could find related to diesels or not. I like the idea and I am ready to try to build one, if anyone out there has came across plans for a diy kit specific for our trucks please send it my way, this would help out alot. I tryed doing searches on almost every forum I could find but with no luck, if I has a sabb I would be in luck,lol
Thanks in advance.
International Threat
I dunno about water/meth DIY kits but you can speak with RodSlinger because he has a water/meth kit on his truck.
well i found the plans to what looks like a good kit, I am just unsure of what size nozzle to use and what to set the boost switch at to turn the system on, from what im reading the boost cooler systems come with 3 different jet sizes to try.if ne1 can point me in the right direction on how to tune it thats all I need, even if it is just a starting point, this is the link to the plans that I will most likely use
http://www.turbomirage.com/water3.html
I've got the Snow Performance kit on mine and I'm running two - a 375 and a 625 nozzle.
rodslinger, I have finally made up my mind as to what I am going to do, staying on the conservative side I am going to use a 300cc injector set to go off at 5-8 psi of boost and a second at 300cc's set to go off at 12-15 psi, does this sound right to you if I am mainly focusing on fuel economy? also while I am waiting for everything to come in can you give me some tips on where is the best easiest places to install the nozzles and the pressure switches?
Thanks in advance
1 - 5 of 5 Posts
