It all depends on when the last time the truck went into regen......but figure if the truck just finished a regen, then about 400 or 500 milesYes, got em today. Loaded them and did a test drive. Great power, smooth shifting but I didn't go far as I'm waiting for the delete pipe. Does anyone know how many miles are safe for testing before clogging or possible damage to the DPF? if any?
Mine does that too from time to timeGot my tunes today. loaded them, the trucks runs great. Does anyone notice a surging/pulsating idle. Mine does it when it sits in neautral.
Did you install your delete pipe?twin turbo
it sounds like it has a bad aasass cam in it the way it idles.... will it go away.... thanx.btw. not much black smoke. will it smoke more later.... hopefully.
Mine is pretty much a dead steady idle. (210 tune)twin turbo
Yeah and it really rolls some smoke.....I notice it happens when the truck has been sitting for a couple day and I fire it up. How many miles do you have on the truck? When mine starts that non-sense I run it like a bat out of hell and it usually clears up, I'm thinking I might need to run some cetane booster and injector cleanertwin turbo
Is that with the KEM or Dashdaq?Mine does that too from time to time
Its with the KEM.....Is that with the KEM or Dashdaq?
How odd mine runs fine, I'm running the tow/perf.Its with the KEM.....
Oh it runs fine, its just when the truck has been sitting for a couple days it might do it, but it doesn't do it all the time........How odd mine runs fine, I'm running the tow/perf.
