1 - 19 of 19 Posts
Hey guys I have a 2000 powerstroke and I'm having some hard start issues. When I got it the guy indicated that it is "cold natured" due to needing glow plugs. He supplied a brand new box of 8 plugs with the truck. So far I have installed the new glow plugs, tested the glow plug relay which is fine, installed new UVCH's and pigtails, new fuel filter, new thermostat, fresh rotella t oil and filter, new starter, new batteries, new block heater, and K&N filter. The truck runs awesome when it's warm but getting it to start if the temp is below 35° is very difficult. Not sure if this is common or not for a 7.3 but I have to plan an extra 45-60 minutes in if I want to drive it anywhere when it's cold. I've tried cycling the glow plugs 3-4 times and it still just cranks and cranks. It sound like its wanting to start but the only time it will is if I keep cranking it or plug the block heater up for 30-45 minutes. I know they run rough until they warm up but even getting to that part is hard for me. I don't know what else it could be? My friend had a 7.3 and he said he could crank it in any weather for about 10-15 seconds and it was running. 10 minutes later it was warm enough to drive. He said he never plugs his trucks in. When I plug it in, my electric meter spins like a top. I wouldn't mind if it had a thermostat so it wasn't ways drawing 1500 watts but it don't. I can't leave it plugged in all the time and pay a $250-300 electric bill every month. Any suggestions? Thanks guys.
How did you test GP relay? unplug oil temp sensor does it get better our worse?
Sent from my SPH-D710 using AutoGuide.Com Free App
I used my my digital volt meter to check the constant hot side then cycled the key to test the ignition on side. Everything checked out. Where is the oil temp sensor.
Injectors.
It runs absolutely perfect after it's warm, seems like bad injectors would always be bad not just during startup, I'm not sure? I'm starting to suspect it might be the glow plug relay after all. It was before I changed the glow plugs when I tested it to make sure before I took the valve covers off. I didn't realize it was white smoking out of the stack until today. From my understanding, that's a good indication that the glow plugs aren't firing. I'm going to go out there now to test with my meter again. If it fails, I'll jump across the relay for several seconds and see if it fires. Also, here is a video to give a better understanding of what I'm talking about. By the way, I cycle the glow plugs 3 times before initial startup, then once, then 3 times again on the third attempt
As injectors age and wear, their performance in the cold starts to slip.
I can start my truck down to about 35 degrees without glow plugs. It does NOT like it, but it will start.
Discussion Starter #7 (Edited)
That's understandable but wouldn't they have poor performance all the time not just on startup? When it's warm it runs and drives like a brand new truck. If I start this truck and drive it in the morning, it's usually fine the rest of the day. Starts right up no problem. But if I let it sit for 24 hours or so then try to start it, I have these problems. I just checked the glow plug relay and it was reading 12.4v on the hot side and 10.2 when I hit the igntion. I have to new batteries 1000 cranking amps each. Looks like when I complete the relay circuit by turning the ignition on, that pole would be reading the same 12.4v as my constant hot pole. :dunno:
Also, it's 19* here right now. In all honesty it's starting like it did before with the old non functional glow plugs. Considering I have installed new glow plugs, new under cover valve cover gaskets/harnesses and new pigtails on both sides, the only other thing I can think of is a faulty glow plug relay. Hopefully it's not the injectors.
What weight oil are you running?
You can also just jump the terminals on the GPR and see if you get better starting.
15w40 Rotella T
Just so I understand, if you plug the block heater up for 45 minutes it starts fine/normal?
Sounds like your relay is fine due to the 10 volts you got when the ignition was switched on. Did you test the glow plugs before installing?
Discussion Starter #11
Takes a few seconds but yes it starts with the block heater. I didn't test the glow plugs as they were brand new.
I am betting glow plugs related. Based on what you've told us it is definetly temperature related. Anything else that would cause this that is affected by temperature. Injectors? Low compression maybe?
Shouldn't be a 2+ volt drop on a relay. I'll bet that changing the relay will make a HUGE difference. Mine did. I even broke the old one open to see why. Horrible contacts. Jump the relay or get a new one. GPs pull huge amps so that won't let them work at peak.
Discussion Starter #14
Yea based on the smoke from the stack in the video I posted and the difference in voltage from pole to pole Im also suspecting the relay. I'll stick a new one on it tomorrow and see where that gets me. Thanks again for all of the help guys hopefully this takes care of it.
Discussion Starter #15
Update guys. I installed a new glow plug relay, cycled my "wait to start" about 3 times and after about 3 seconds of cranking she fired right up. The truck had not been started or running for 24 hours prior. I'm happy : )
Thanks again guys.
if it happens again, you might check into the stancor relay
One of the best mods I've ever done to my truck was adding a Stancor.
It will happen again. I'm guessing three times faster than it should. ;)
1 - 19 of 19 Posts
