1 - 11 of 11 Posts
Last year my truck began to struggle to start when the temps drop below 20 or so and sometimes it wont start until the temps warm up later in the day. Im getting ready to replace the blockheater but it always started without the heater in very cold temps.
The alternator and batteries are 2 years old so those should still be good but I was wondering if a weak starter could be causing this, or Glow plugs?
What should I check first?
Check for codes
Verify EOT is accurate at ambient conditions (EOT, ECT, TFT, IAT should all be approximately the same after the engine has been off for 10-12 hours).
That ^^^. ...and tell us your FICM voltage during a cold start.
I agree. Whatever you have going on, it will probably show up in trouble codes or on the monitor itself. It could be something as simple as a few glow plugs not working.
k
Also, since you ask about a weak starter, you need 150 rpm to start. You normally should be at 180 rpm IMO.
I'll check codes when I have a minute.
The ambient temps seem normal. What would a problem with the ambient temps look like ?
I haven't checked FICM voltage lately but it was good last time I checked.
Thanks guys
Really wish people would state the year of the truck and any major mods in the Opening Post
I need more coffee
The glow plug controller should report if there are bad glow plugs -- no codes? -- then the controller is bad
Multiple glow plug codes : 2,4,5,6 Since they are on both sides, I am going to guess the GPCM.
Thanks a lot man, I wasnt sure.
Any brand or specific model I should be looking for?
I will check some connections and make sure thats all well and good.
The connections in the harness plugs at the GCPM can burn -- pop the colored terminal protectors off an look closely -- may need the harnesses
O'course you could just have burned out glow plugs
pulling the inner fender liner helps a lot when replacing glow plugs
1 - 11 of 11 Posts
