I guess I'm not following you if I return to stock and start engine with no sensors hooked up I am going to get all sorts of codes and engine lights. Brake lights function normal although I think it's somthing to do with the update because the one you released just prior to I had no problems with, but it did rattle so I updated again when you released that version and that's when the problem started. Oh well I'll figure it out
Correct, you will get all sorts of emissions codes. Drive it for a few miles anyway and then check to see if one of the codes you get is the Brake Switch. As we said, you will get one start once returned to stock and the sensors are unplugged. After that one start, the truck will not crank and you will either need to clear codes to get one more start, or re-install DPF removed tuning to get multiple.
We feel like it is not related to the update, thousands of other trucks running the same tuning that you are without this problem. It may be how your truck responds to the update, but we wont know for sure until you have removed H&S from the truck and tested to see if the code is still there.
We are happy to help, but diagnosing with limited information is very tough to say the least. Especially when thousands of other vehicles with the same truck/tuning have not reported anything similar.
If it is something to do with the update, we will bend over backwards and dive in to our software to fix the issue. But we cannot do that until we know for certain that the truck doesn't have the code when returned to stock.
Please give it a try and let us know what happens!
