1 - 7 of 7 Posts
just noticed today that my pyro 1 on my 08 is showing the temps as normal but then would drop and spike back up with no adjustment or difference in load on the engine (600f - 200f then back to 650f) all in a second.
is that the factory probe failing?
More than likely.
its the same sensor thats in the dpf so if ya still have it you can swap it out with no cost to you!
Does your mini max have the latest firmware and updates?
Sent from my broken a** Droid X
MIne did the same thing. Factory probe went bad. $34 to fix it. And while the connections are the same for the probes in the DPF, the insertion depth is different. Not completely sure it will fit.
1 - 7 of 7 Posts
