1 - 20 of 31 Posts
Besides a cold air intake do you have to have any other performance mods to run hot damn 300?
Sent from my iPhone using AG Free
Don't you worry about it
2017 F250
studs might be in your future
2017 F250
And I dont think any drop in filter will work without sucking in the filter minder.
Don't you have to remove the cab to change the studs?
Yeah it's a Turbo Diesel
That's right, it'll suck it down. Gotta do an aftermarket airbox and filter
Sent from iPhone
2017 F250
I even have to run my S&B without the lid. These things move some air!
Oh rly, so I'm being a pansy driving around on easy?? :) If HD300 means studs then I will stay away and maybe give the mild a try.
I run the hd300 daily no studs. I just don't hammer it all the time, hardly ever actually. Just when a ricer needs put in his place lol
Sent from iPhone
Sent from iPhone
same here :D and i got my fuel @ 5 but it looks like mpg went down so im going back to 3 help the environment too :p
2017 F250
Good for her! He needs an intake.
to get the full benefit of the HD300 tune you must use a cold air intake kit as well as a 4 or 5" straight pipe.
For insurance/security, it is in your best interest to get egr delete and head studs.
you will also see a small (i said small) increase if you replace your cold side cac tube.
i did.
the difference you look for is your peak egt after/during a WOT run. i had a 5" straight pipe and saw a drop of 130* in a quarter mile race over against a cat/dpf delete. cruising temps will be no different.
you mean in addition to a DPF delete right?
Discussion Starter · #20 ·
Yes. I plan on deleting the DPF and installing a cold air intake the same time I install the programmer. So is there anything else I need to change?
1 - 20 of 31 Posts
