Im sure this question has been answered, but can seem to find it. The power wire the is suppled, can you tap into the ingintion wire like the 6.4L or do you have to tap into the fuse box?
I havent had a chance to look up under the dash yet, just doing some research.
I just put my mini in last weekend you tap into the passenger side of fuse 52 in the fuse box by the vacuum booster
Redrider8293 - thanks for the reply
I pose another question - is there a keyed ignition source wire under the dash that is hot on start up and run? (hope that makes sence).
Tring to keep the H&S power wire under the dash.
