I started installing my mini maxi for my 2013 F250 tonight and ran into a power issue. It says to run a wire to the fuse box (Passenger kick panel) and I don't see an easy way to get a wire over there without taking the dash apart. There has to be a wire directly under the driver dash so I can have the unit turn on/off with the key... any help would be appreciated.
check underneath the steering wheel column by the dash. I installed mine and found a wire that is powered only when the ignition is keyed. I can't remember what the color code is but I thought the same thing when installing my race tuner a couple weeks ago. I didn't even want to run the separate power wire to the fuse box, but then I found the instructions saying you can find a wire and tie into that.
