1 - 20 of 28 Posts
This morning woke up went out and tryed start truck and nothing would happen so i jumped it off and now the engine light is on and H&S mini maxx is giving me two codes, anyone had this problem? or can anyone help with it?Codes are
PO68A
PO64C
looks like it has something to do with your glowplugs
P064C - Glow Plug Control Module
P068A - ECM/PCM Power Relay De-Energized - Too Early
Not for sure where to go from here, but im looking!
Thanks for the help man! i have what the codes are now but dont know if there something to take to dealer or just clear them out with H&S...
try this. Put the truck back to stock settings with your H&S - but do not start truck. Once all settings are put back to stock, reprogram the truck with the H&S tunes and see if that helps. Seems as if something was left on your truck.
But you would think that it had nothing to do with the programmer, im not for sure i will try that and see what happens.
After looking at others that had the same issue, it looks like it was battery related - due to a low battery the PCM couldnt fully engergize when the key was turned off. - Someone said that thier PCM had to be reflashed. Still looking!!!
If it needs be reflashed wont that mess with my H&S? and is that something ford does for free? never had to have this done
IF you have to have it reflashed you will need your truck back to the stock settings. (which means you may have to have it towed) - I have heard others say that once ford reflashed the PCM to have them not to start truck until you reprogram with the H&S tunes, then start truck. Now as far as price, not to sure it will be free - since im sure ford will say and try like hell to say that your aftermarket goodies caused the PCM - or what ever else the root of the problem is. If it was my truck i would start with taking truck to stock (dont start eng) then reprogram with H&S tunes and see if that does anything - prob going to say that it wont - but never know. When i put H&S on my truck i threw a code for something crazy - not for sure of the code - i posted a column on it - i took the truck back to stock - then reprogramed and all is great. Ford cant even find a trace of the code.
Discussion Starter #11
Why would it need to be towed?
oh my bad, didnt know if you truck was running or not. I may have missed that your truck is running, just has a CEL.
Discussion Starter #13
yea i got it do jump off and everything and it starts when i turn it off now, what doe you mean CEL?
Sorry about that - bad habit from the military - Check Engine Light
Discussion Starter #15
Thats ok man, Have you had any tranny or motor problems with yours with your tunes?
Not a prob. The truck runs amazing.
Sent from my MB855 using AutoGuide.Com Free App
Discussion Starter #17
Well those two codes are gone now I have a code
P0884. Any idea what that is
Category Powertrain
Definition Transmission Fluid Pressure Sensor/Switch "A" Circuit Intermittent
This is what ive found so far doind some research
Discussion Starter #19
My tranny is fine from what I know
DTC P0884 (PCM/TCM power input signal intermittent)
Here is what i found again
1 - 20 of 28 Posts
