got my guages and everything else installed that i ordered (Guages, S&B intake. 7in turbo back stack kit, Wicked wheel, overboost annihilator, Z-plate) and i already have a ts chip. My question is what are normal readings on the guages. i kno this has probably been asked a million times but every truck is different with different mods. i also have a lift with 38in tires. i noticed today when i was cruising at 65-70 mph i was pushing like 5 psi, 800 deg. on my exaust and 125deg on my trans. what is the max temp your exaust should get up to. if i crank the chip up it will hit 1250 1300 but i let off at 1250. what is the most i can push it without damage? thanks!!:dunno:
