Alright everyone, been trying to sort this one out for a week now and I could use some help. I'll explain what's going on then list all the parameters I can from the truck.
I've had the truck for about 2 years now and when I initially purchased it had a bad miss. Tore into it and deleted the EGR Cooler, replaced the oil cooler, new ICP sensor, new fuel filters and did other minor updates like: turbo oil feed line, turbo drain tube. Also installed new Y pipe and installed regulated fuel return. The miss turned out to be cylinder 6 because the bolt through the spool valve came loose. Replaced that injector and retrieved the hardware and the truck has ran fine for a year aside from slow starts at low fuel levels and the truck "running out of fuel" at 1/8th tank because I'm 99% positive the pickup tube in the fuel tank is broken. Plan to resolve that with a Beans Sump at some point.
To date I have only put about 25,000 miles on the truck since I've owned it. 6 months ago I was having trouble with cold starts and a bad miss again during the winter time. I took the truck to my local Ford dealer and had them run a contribution test. Results were all over the map but the only injector that showed up consistently was #4. It was chaotic though because the power supply on my FICM was failing and reading only 36.5 volts when cold. Replaced the FICM and the cold starts got much better but still not great and my fuel mileage has been lacking (11 mpg around town and 16 mpg on the highway). Never did the contribution test again after the FICM because they charge $250 per test.
3 months ago I noticed she was leaking a decent amount of oil. Tracked the leak to the oil cooler housing and one of the 319 Orings on the oil cooler itself and have been putting off repairing it for some time just because I don't have a lot of free time and as most of you know, getting to the oil cooler is pretty labor intensive. Because of the leak I had been refilling the truck with about 4 quarts of oil per month to maintain proper level until I could find time to fix the leak. A week ago I refilled the engine with 15W-40 Valvoline. Whether it's because of that or coincidental, two days later she starting pouring grey smoke from the tailpipe and I had a big loss in power. At WOT the smoke would go black and get real thick so it's obviously fuel. Seemed to me that the smoke would be from an injector spintle stuck open and dumping fuel into the cylinder. I have a ScanGuage II hooked up but for some reason my truck doesn't like to share DTCs with it. It always reads Not Ready when I try to retrieve codes. So I really didn't have a good idea of which cylinder was the culprit but this weekend I decided to tear into it to fix the oil leak and replace two injectors in hopes of getting lucky.
Unfortunately, I was not. I replaced injectors 4 and 7 and changed the oil to Rotella 15W-40 which I've used before but the smoke persists. On the bright side, the oil leak is fixed lol.
So, currently, the truck still smokes and runs like crap with new injectors in #4, #6 (1 year ago), and #7. New and improved Bullet Proof Diesel FICM power supply, no EGR cooler, stock tune and properly functioning turbo. I even took it over to AutoZone yesterday after it was put back together just to see if their scan tool could pull codes since my ScanGuage doesn't like to but no codes were stored. I had the batteries disconnected all weekend though so that could be why. I should also note that I pulled every injector this weekend just to inspect them but couldn't find anything obviously wrong. Replaced #4 and #7 firing from the hip.
Can anyone tell me if I'm right or wrong about a bad injector causing the smoke and lack of power? If so, how to track down which one it is without buying an expensive diagnostic tool, paying Ford another $250, swapping the new injectors into different holes one at a time, or buying 5 more injectors?
Parameters:
2004 F-250 King Ranch
200,000 miles
Pre 09/2003 6.0L
FICM Main Power Voltage = 49V
ICP at Idle = 640 psi
IPR at Idle = ~29%
Boost is normal at any given throttle position (0-24 psi)
DTC's are unknown
Didn't notice any fuel in the oil when I drained it this weekend
No loss or gain of coolant in the degass bottle.
If more specs are needed just reply and let me know and I'll post. Frustrated with this and ready to resolve it. Love this truck to death and when she's healthy she runs like a banshee. Thank you in advance to anyone interested in helping me sort this out.
Parameters:
200,000 miles
Pre 09/2003 6.0L
IPR at Idle = ~29%
DTC's are unknown
