1 - 8 of 8 Posts
Hey guys!
Well I just bought a wrecked 2006 F250 FX4 King Ranch Lifted 37's Well right now its in the shop getting allllll fixed up. now I talked to a couple people and they told me that if I do straight exhaust,EGR delete and light tuning ill bee all good? JW is he right? Well I'm gonna be buying some parts here before long.
Well I decided to go with a MBRP 4in straight pipe. Idk what EGR delete kit to buy? i dont wanna cut corners i want it done right! So help me out with a egr delete kit. Also Im looking at tuning. I was looking at SCT Also the Banks 6gun. I like that the 6gun has a 6 position selector switch. But my only question with it with this put major stress on the hed gaskets? not trying to cut the corner of not doing gaskets but I just dont have the cash to dump into head gaskets. Well got 2 more questions. What brand of oil cooler should I use to replace it? and the last one is Can I put APR head studs in without new gaskets If I just do them 1 at a time?
Thanks for the help!
Ron
P.S. If you have any input PLEASE throw you 2cents in!
Ron!
Best answer for me is to read the thread at the top of the page in the stickies Bulletproofing the 6.0 by collo_dually. That'll answer everything you need.
Anybody got anymore input?
If its running ok now, just save your money and do it all once you see your delta exceed the limit, no need to pay for the same labor 2-3 times when you can do it all at once. And then tune it with sct and drive it like you stole it, its fun, trust me!!! :scuffy
Hey guys!
Ron
Ron!
For the EGR cooler I would do the IPR stage 2 EGR delete. It is by far the best EGR delete I have seen IMHO. I would aslo put and IPR high flow coolant filter on the truck and flush out the ford gold coolant and put ELC coolant in. For the tuner I would only go SCT since it tunes the transmission also. For an oil cooler the only three options that are proven to work are to replace with another stock oil cooler, use the IPR oil cooler kit which moves the stock oil cooler out of the valley to the radiator for easier anc cheaper cooler changes later down the road, and the bulletproof oil cooler whci you put on and never have to worry about changing a oil cooler again since it is an air to oil cooler it will not clog like the factory one will plus eliminates the stock cartridge oil filter and puts on a frame mounted spin on oil filter. As far as studs it is recommended to pull the ehads and have them checked for flatness and cracks and reinstall with studs and OEM ONLY gaskets, but if your headgaskets are not leaking there have been people that have done the 1 for 1 swap over to studs and had good luck, but IMHO it is kind of a shot in the dark in how long it will last if you do not have the heads checked.
War is the answer!
This is the first thing you should do......http://www.powerstroke.org/forum/showthread.php?t=259257
Dont bother with the bully dog stuff, some ficm tunes are safe for trucks without studs.
To the OP, if out know for a fact that the gaskets are good then you can do the studs one a a time without removing the heads but baring your certainty the gaskets need to be replaced, heads checked and studs put in after.
Nothing wrong with the bullydog stuff. I ran their triple dog tuner for 190, 000 miles no issues. I'm not sure he said anything about ficm tunes but the best one for all around performance is the atlas 40 film tune which is good for oem head bolts.
Sent from my SPH-L710 using AutoGuide.Com Free App
1 - 8 of 8 Posts
