1 - 10 of 10 Posts
Ok my truck was running good till Saturday, no problems at all. Then I went to the car wash to clean it, I washed the motor while it was running and since, it will only turn over.
I have checked everything and I have a edge platinum install and the harness was really wet. I also have a sct tuner. Ficm is at 48volts and I unplugged the icp. Please help me!!!!!! Also ordered a uses ecm off eBay. :dunno:
Check every connection under the hood. If you hit something with a pressure washer it may have knocked a connector off. Otherwise let it sit and dry out and let is know after that
Sent from my DROID X2 using AutoGuide.Com Free App
First problem was power spraying an engine, especially running.
You risk shorting out electrical components as well as cracking a block or other hot surface with cold water.
Take off the Edge and try the truck stock.
I have taken off the edge, it's all stock now. Also it's been dried out since Saturday. I'm really lost on this one. I have learned my lesson it's best to keep a little dirt on the motor. I have looked At all the connections that I can think of and also checked the fuses.
If you think everything else is good, you coulda fried something
I made my Samsung SGH-I997 send this.
I need you guys to help me find the icr on my truck. If you could can you send some pictures? The scanner was only reading about 22 psi max.
Icp?
I know somewhere in that year range the location changed.
What's your build date?
Not necessarily. Could be IPR, could be HPO leak, could be ICP or ICP pigtail, and finally HPOP. Well, could have no LPO for some reason.
1 - 10 of 10 Posts
