1 - 11 of 11 Posts
Dirtleg
looks good havnt drove around yet to see if the egts droped any, but i found my smoking problem the boost tube and the intake have oil all in them the intake is all caked up. is this a sign of a bad turbo seal
Not sure if its a bad sign but when I put my CFM on I found the same thing. I asked acouple diesel mechanics at my local dealership and they said that it was normal:dunno:
yeah I had to clean alot of oil out when I did my intake elbow also if you don't get it clean out it might blow off also
Rice Hunter
Pretty norm for these 6.0L
It doesn't take long to coke up at all
I rerouted the cc vapors to a frame rail filter and then back to the intake tube. It took a while, but the filter finally got saturated and I drained several tablespoons of oil out of it yesterday. It is a GREAT mod. I installed it so that the ccv tube initially takes a vertical path up and over the brake master cylinder. From there, it goes down to the frame filter in a constant slope downwards (I made sure I did not create any pockets to trap oil and create more back pressure). From the filter, it is a constant vertical slope back up to the intake tube. It is working VERY WELL!
Dirtleg
Discussion Starter · #7 ·
i read alot about this ccv mod but will it drip oil out all over the drive way after you turn the truck off if you dont put a canister on it
Dirtleg
Discussion Starter · #8 ·
here is a couple of pics second one is a little blurry
Dirtleg
Discussion Starter · #10 ·
i have no clue mine is not taped but it has the hole to be taped, i run the edege insight monitor
1 - 11 of 11 Posts
