1 - 15 of 15 Posts
Im going to change my glow plugs out this weekend my question is will i need new valve cover gaskets when i take off my valve covers or not? Thanks Evan
Where did you get the 05 update for your truck or what did you get to make it that way and what did you modify to make it work
Powerstroke Junkie
NO as long as the old ones are in good shape they can be reused, I would also upgrade your GPR to the Stancor relay!!
NCH
sorry anthony i cant help you out about the updated front end as it came like that when i bought it but im sure someone on this fourm can send you in the right direction and as for the relay that was the first thing i bought and changed already thanks for the help
Just from the sig pic it looks like a 99-04 bumper, 02-04 heads/parking lamps & '05+ grille (which I believe it needs to be trimmed at the bottom by an inch or so to fit the bumpers used from 99-04).
Semper Fi
There are lots of them available for 7.3L, are there any specific brands one should purchase over others? Any brands to stay away from?
ok one more question im about to rip the truck apart tomorrow to put the new glow plugs in anything i need to look out for or any tricks to make it easier ?
they are alittle tuff to get out use a DEEPwell and make sure u have a swivel socket for the back valve cover and u can use some tubing to put ontop of the gp and pull them out
have u updated ur under cover valve harness connectors? if not do it while ur in there
Discussion Starter #11
No i have no idea what those are or the reason to do that pleases explain?
their are wiring harness going into the valve cover and they come apart nd make ur truck run like crap or not run at all it is a clip that holds them together better. Not sure how much they are
Discussion Starter #13
Ok do you know where i can get these at and when i take my valve covers off to change my glow plugs will i see them like is there no missing them ?
Powerstroke Junkie
There is a harness under each VC that plugs into the main harness in the valley of the engine. It is this connection that comes loose. The clips can be purchased at Ford only.
NCH
Discussion Starter #15
Can anyone give me a specific name that i would ask for when purchasing?
1 - 15 of 15 Posts
