Hello all new here! I am pretty mechanical but when it comes to deisel diagnosting I am lost. I own a 96' F350 7.3 4x4 4 door. When I got the tuck it had a utility box on it and I was averaging 18 mpg. Over time i switched the bed out for a regular bed. Now over time I am down to about 12 mpg now. I came to the conclusion that the map sensor was bad do to power loss. I replaced it and my power is back. I also replaced ebs tube. ( Now shifting better) I noticed the other day when I changed my fuel filter that the fuel heater is disconnected and obviously broke. Will this have anything to do with fuel milage? Also I know my glow plugs are not working, but I keep the truck plugged in when temps are below 55 degrees. Also was wondering if anyone has ever used starter solenoid to replace the glowplug relay. Seems like same set up and 15 bucks cheaper. Any suggestions or help would be appriciated.
Thanks Dave
Thanks Dave
