Every since we got our new much heavier trailer (usually between 10-11k pounds) we have been getting this.
It usually happens when starting out in granny 1st and shifting into 1st gear. By that time when shifing into second the truck is rolling enough it will stop doing it.
It doesn't bother me persay, I just don't want to bust a U-joint and end up stranded.
A little background, the truck has a set of blocks in it that are 1 inch taller than stock to level out my leveling kit lol. I run the airbags so the truck is close to my unloaded height. My truck sits failry level unloaded. 1" inch high in the back, not the normal 3 inches or so of cheese wedge factory look.
When I was towing 7k pounds my truck never did this nor did I feel the need to start out in granny gear with that trailer. With the new trailer I feel like I am abusing the clutch to get the 10k pounder rolling if I don't use granny 1st.
It does it really bad when taking off with any kind of uphill slope.
My opinion, is that the increased weight is wrapping the axle up to the point of u joint binding. To me this is a different kind of driveshaft vibration then say a lift induced angle problem.
So my question is, would I try shimming the center bearing up or down?
If the axle is winding up then wouldn't dropping the center bearing compound the problem?
I apologise for the wordy thread but I wanted all the details I could give.
Advice?
Advice?
