1 - 9 of 9 Posts
Hey y’all, new to the group comin’ at ya from Magnolia, TX.
Just put 37s on my 1 ton long bed, as expected, she’s sluggish.. Currently running the factory 3.55. Weight reduction, tuned, and 5”. What gears are you fellas running with 37s, and do you like’em.. Pros/Cons
Thanks for any help/feedback in advance 👍🏼
I run the same gears(3.55) and what not with my 37’s. Got used to how to apply the power and see no need at all to change. Took a little getting used to though, I will say that.
To get you back to a stock ratio, you'd need 4.09190..... so somewhere in that area would get you back to a stock feeling truck but with 37" tires.
Im curious as to what 37's and 4.30's would be like....Considering 4.30 is an OEM gear and all.
Thoughts?
Thoughts?
Use the formula
RPM= MPH x axle gear ratio x transmission gear ratio x 336 divided by tire diameter in inches
This website does it for you Gear Ratio Calculator
6R140 gear ratios 1st-3.97 2nd-2.32 3rd-1.52 4th-1.15 5th-.86 6th-.67
Use the formula
Good info, thank you!
I got my tunes modified and it helped. Shift point mph raised up, but our transmission learns so fast it did not last long. I want to swap gears also but that top end rpm at 100 mph is still decent with 3.55 gears
Thoughts?
I have 37’s on a 7” lift and decided to go with 4.30(Yukon Gears). Love it! Really glad I didn’t go with anything less.
1 - 9 of 9 Posts
