1 - 20 of 41 Posts
Just wondering what everybody else out there was getting for gas mileage?? I have got an 05 F250 6.0 diesel, 8 inch lift withh 38" tires. Air intake, full RBP exhaust, SCT Livewire with custom tunes from DJ's (always on tow tune). And I can't seem to get any better than about 10 mpg... So now it that diesel is getting up over $4.08 a gallon, it takes me $100 to fill up, and I get about 250 miles per tank. Ya I think you know where I am going with this. So what is everybody else getting? and what can I do to get BETTER mileage??? Please help...
What gearing are you running in the rear with the 38's
Whatever that factory gearing is?? I thought about getting it regeared this summer, but I am not even sure what to gear it at??
With the 38"s i would regear to 4.30s from the factory it probably has 3.73 gears
That would put you close to stock gearing again and get you up to about 14 or so if you are getting 10 now
take lift and tires off and dont go over 35's u will gain a decent amount
Matt
how do you know its 10mpg...have you recal your speedo?.
i would regear it if you really care about it. any thing over 35's you really should
First you should definitely regear. I am getting ready to go to 37's myself (this week), and have the regear not far behind.
Discussion Starter · #12 ·
Well I would NEVER take the lift and tires off, so that is not an option I guess... I know its about 10 mpg because when I fill up the tank (25 gallons) I get 250 miles before its empty... hmmmmmm
I would go to 4.30's and figure about $1800 or more to have it done
COLLEGE KID
You could re gear it yourself. Ive helped do it in a jeep. It you know someone with some tools and a press and You Follow the directions Labor would be free. Its tricky if you have never seen it done. I helped do it once and I think I would tackle the job with an extra hand no problem. I know was a small jeep but the basics of the job stay the same I would imagine.
With 35's I'm getting 15.6 around Tampa. and my meter is dead accurate. I couldn't imagine going bigger than 35's in terms of MPG's. I think a factory 275/60/20 to a 35x12.50 is a good range of tire for practicalness.
Did you recalibrate your speedo to account for the 38s? Try going easier on the skinny pedal
i get like 17-18mpg. i try to take it easy as much as possible though
Discussion Starter · #19 ·
Ya I try to take it easy MOST of the time...Never really gotten any better than about 10-11 though...
I am in the same boat, 8" Fab-Tech with 37" Toyo's. SCT tuned to "Street" everything else stock. And am getting about 10 mpg. And yes, I did recal the Speedo using the SCT.
1 - 20 of 41 Posts
