That will help! ThanksHere are the measurements from my 07'...I used the front of the bed as a reference since using the tailight would be crazy.
1.25" down from the center of the lower body line (level with the body line)
60.25" from the front of the bed to the "front-most" point of the decal. This is for both sides...I double checked it....measure twice, apply once.
Hope this helps!
Thanks!!!!!I changed mine from FX4 to the Sport 4x4(an OE F150 decal). I bought them from the dealership and the paper was already cut to a template to match the curve of the tail light so it lined up perfectly. I matched the curves, made marks where it should go with a dry erase marker then pulled the paper off, applied and cleaned off the marker.
I think I did great job on it.:thumb:
(This is an earlier picture of my truck.)![]()
