I have the F106S pointed straight down. I drain it straight into a 5 gallon race fuel can without a hose. That's just because it's convenient though. If I went straight out I would use a hose for sure.
How are you pointing it straight down when it comes out the side?I have the F106S pointed straight down. I drain it straight into a 5 gallon race fuel can without a hose. That's just because it's convenient though. If I went straight out I would use a hose for sure.
Out of those two, I would recommend the 90° one. You won't need a hose. Especially if you drain into a 5 gal bucket like most do.How are you pointing it straight down when it comes out the side?
Here are the 2 I am looking at.
Fumoto Original F316L FL-Series Engine Oil Drain Valve, 1 Pack, Bronze https://a.co/d/iQrNMz1
Fumoto F106N FN-Series Drain Valve with Long Nipple with Lever Clip https://a.co/d/a2qh21t
Nope wide open on the 6.7Not sure if the 6.7 is the same as the 6.0 but, I had to cut the 90 completely off to fit behind the starter.
That’s for coolant not oil. And I installed my 90 just fine behind the starter and I have a hose connected to it to drain it into buckets. Both sides. I left the oil drain valve off for this oil change and will install it on the next one. I had a reason at the time for not installing it but damn if I can remember what it was. Getting old isn’t for the weak.Not sure if the 6.7 is the same as the 6.0 but, I had to cut the 90 completely off to fit behind the starter.
Ya, maybe mine is failing as well.That’s for coolant not oil. And I installed my 90 just fine behind the starter and I have a hose connected to it to drain it into buckets. Both sides. I left the oil drain valve off for this oil change and will install it on the next one. I had a reason at the time for not installing it but damn if I can remember what it was. Getting old isn’t for the weak.
I was curious about this myself so I checked. After draining my oil to a drip, I pulled the valve. Got a whopping 4oz when it returned to a drip. How much of that was oil still draining off the engine internals? Dunno. I always drain after driving for a bit to warm the oil so maybe some.On the 6.7's, how much oil does the Fumoto block from coming out the drain?
With the Jeep 2.8 holding so little oil in stock configuration, it's a decent percentage. - on the Jeeps the Fumoto threads in deeper than the pan and blocks a certain amount of oil from coming out the drain hole
I have the 90 degree that points down. I like that one, less oil blowing when it’s windy.How are you pointing it straight down when it comes out the side?
Thanks for that! My wife's new car needs one.For those looking to get one Fumoto is running a sale.
Buy Fumoto® Valve Online | Replace Oil Drain Plug
