1 - 8 of 8 Posts
I'm starting the conversion of my 97 7.3. I've managed to find a source of oil so the first step is to build out my filtering needs. My plan is to use the dieselcraft OC-20 centrifuge. They suggest their own pump which has characteristics quite similar to the RawPower pump. Rather than purchase two pumps, it occurs to me that I could simply use one for both purposes. In short, I could build out a second loop on the pump to push to the centrifuge*. Back into the garage, hook up the lines, and filter my oil. It's a minor difficulty making a power disconnect to run the pump on a line driven power supply. What I'm not so sure of is if the use of one pump would ultimately be a detriment to wear. Given that the suggested dieselcraft pump is in the neighborhood of $650, and the rawpower pump is around $500, and given initial investment v. replacement down the road, I can see it as being no different to use one pump rather than two. And, to top it off, if I want to make a mobile filtering works, it's all right there. Any thoughts?
*Just to clarify, this is a separate loop going from waste collection to a filtered storage rather than waste collection through the fuge to the tank as it seems multiple passes with the dieselcraft oc-20 may be required.
with all of that money you are investing Id just get an open bowl type centrifuge and a cheap harbor freight clear water pump. The problem I have with those pressurized centrifuges is that if the system pressurizes from a block or whatever reason then it just contaminated all of your clean oil. Id rather heat and settle oil into a conical tank and then take from the top and filter that oil into a house water type filters.
Reactions: _hojo_
Is this a common problem that you've seen even with proper pre filtering? I planed on using a 60micron pre filter. If blockage is an issue within their normal operating range then I'll rethink it.
Rethink it. Spinner fugues don't quite cut it.
I am just starting my own conversion, so I don't know a lot about smaller vs larger centerfuges, but I am thinking of trying something similar. What is the beef with the smaller 'fuges? All my filtration will be onboard, so a full size unit doesn't make much sense, and I won't necessarily be able to park somewhere warm long enough to let water settle out. So I'm also thinking the dieselcraft mini-fuge driven by the same raw power pump used to run the engine. It would be on a loop so that it pulls from the bottom of my collection tank, heats the oil using a FPHE, then back into the same tank. I'm roughly following this design by sunwizard at burnveg: Dieselcraft WVO centrifuge works great-My filter dewater rig : Vegetable oil Collecting, Filtering and Dewatering. Sounds like he's had good results so long as you let it run long enough to recirculate the volume of oil 4+ times. I'm sure this will add wear to the pump, but I'm thinking that 4/5 hours a month is negligible, and one $500 pump should be enough!
Oh boy.
Good luck with that.
Spinners are just that. A toy. Makes you feel good, but in my opinion only accomplishes a "good feeling".
Either time to settle, or a lot of heat are required to accomplish a good settle. Heat to 300*F and settle for 24-48 hours is sufficient. Otherwise, several weeks at 80*F can accomplish the same result. If messing with WVO as a raw unaltered fuel, dewatering is paramount. Several on this site have learned the expensive way about water and H2O/NaOH do to injectors. It is my belief that an adequate onboard filtration is a dream. A pipe dream. I suggest not doing it.
"Gravity feed " CF's are arguably best. It's what most use who are succesful long term. There are many turn key CF's out there, just avoid the cheapest.
The wheel has already been invented, partly due to failures by some and successes by others. We cannot, however, alter things like gravity and chemistry. Therefore my advice is to stick with what has been proven to work. It's cheaper and causes much less pain.
Did I mention I do not recommend raw WVO as a motor fuel? That's a different post for a different day.
1 - 8 of 8 Posts
