Heres another one for you guys. I was thinking of making my own fuel system with my FASS 150/150. Here are my thoughts. I will completely bypass the fuel cooler and fuel bowl on top of the motor as well as the frame rail pump/filter. Run blue fuel line from the tank to the FASS. From the FASS run a braided -6 line to the HPFP feed. I will utilize the stock HPFP feeds to the heads. From the return side of the heads run a -4 line from each head and Y them together. From that Y I will continue to use a single -4 line that will meet up with another Y fitting. The other line that will meet up to the Y will be a -4 line from the HPFP return. I will run a -6 or -4 line from that Y back to the tank. Do I need to use a regulator on the return side? what about the feed side? I didnt think I would need one on the feed side due to an internal regulator in the HPFP. Also do you think I should turn my FASS down to 10 or 12 psi or keep it at the 40 or 45 that it is? Let me here your thoughts. Ryan
