Addicted to Diesel
anyone know what the ohm range is for the stock fuel level sender on a 2000 f-250? I am trying to find a sender unit with the same ohm range to put in an aux. fuel tank so i can tie into the stock fuel gauge with it. I have a valve that will also switch the reading of the fuel gauge. thanks
Let's go B's!!!!
If i'm not mistaken, the fuel sender applies 15 ohms resistance at empty, and 165 ohms resistance at full.
Hope this helps!
later
Addicted to Diesel
thats what i was looking for. i thought that is what it was, and that is what i had found so far, but i wanted to get some extra opinions. thanks
Let's go B's!!!!
10-4 :thumb:
