1 - 2 of 2 Posts
Fuel pump question for 1997 7.3
Hey! I just converted a 97 f-350 to run on veg! I have a raw power pump pushing the wvo through 2 heated filters at 30 psi then it goes through a pressure regulator that reduces the pressure to about 10 psi then that runs through a fphe then to the stock mechanical pump... It is running great but I'm wondering if pushing 10 psi of wvo to the stock pump (which pulls at 4 psi I beleive) is gonna damage the stock pump? Or if the regulator will make the raw power pump work too hard?... I am pretty new to all this...
R
just get rid of the mechanical fuel pump and make both the diesel and veggie side use electric fuel pumps. My question is you must have a return somewhere back to the wvo tank for all of this pressure to go back to right?
1 - 2 of 2 Posts
