what types of setups you have for your wvo & D2 fuel?
I was running single stock fuel pump for both. after 40K mi it failed. Looking to get another pump was wondering if dual pump or single pump ?
What kind you got?
How many miles on it?
Any pics on mounts?
hey havent seen you around in a while!
I should be working on my upgrade withing the next few weeks. it will have a parallel fuel system, one pump for D2 and another for WVO. i have an OBS and my stock mechanical pump will go away. if i had an SD, i would use my stock pump for D2 and a FASS HPFP for WVO. Leon at wvodesigns is going to be coming out with a new pump for wvo sometime this summer.
i chose duals to reduce purge time, incrase efficiency, failover capability, keep the wvo out of the D2, etc. anyone running a DFA kit will have dual as well.
What kind you got? -FASS HPFP
How many miles on it? 100K+
Any pics on mounts?
Stock pump for both? Sounds like a greasecar kit...........?
I run two electric pumps. My mechanical pump also failed after 30k miles on SVO / d2.
I now have parallel systems. Raptor for the d2 side and FASS for the SVO side.
