A couple guys posted awhile back that they replaced their 96 and 97 OBS 7.3 fuel pump without removing the turbo assembly. I think I can get the banjo bolt off but I`m wondering if the banjo bolt and fuel lines can be moved out of the way far enough to lift the pump out and reinstall. Has anyone done it like this? TIA
You don't have to move the banjo fitting much at all. If you take the bolts out of the filter/water seperator it makes things easier to get the lines removed and gives you some more space. The pump will come straight up after the lines are removed and the bolts.
Jim
Jim
Thanks, I appreciate that info.
