I have a manual trans, so im not as concerned with trans temp. I'm slightly concerned about my fuel pressure being a little low, when I changed my fuel filter, I tried to prime the system, and when I turned the key it didn't push any fuel through the lines, I had to start the motor to get fuel to start pumping. It runs, and idles well however its pretty sluggish until I get to about 2000 RPM. I have an intake, 3" down pipe, and a 3 stage chip. It correct me if i'm wrong, but it shouldn't be sluggish. The only thing I can think of is fuel pump or injectors.
That was a long way of explaining why I was thinking of getting the fuel pressure gauge, however maybe yall can shed some light on whats going on with my truck or if that is just normal.
The other couple of gauges I was looking into are Air/Fuel ratio, Oil Pressure, or Air Pressure. Does anyone think this would be a worth-while purchase, or am I wasting my time and money?
I am getting a pyro, and boost, but they have a boost/vacuum gauge. Would that be better or just a boost gauge?
This is the link to the gauges I am looking at.
Tinted 7 Color Gauge Series
That just made this post a whole lot more complicated, but thank you for all the info provided!
