1 - 20 of 20 Posts
got the truck running , ive installed the fuel bowl delete and regulated return from ITP, my question is , those guys running this setup where have you got the fuel pressure set at , ive set it at 60 lbs and it runs fine , the FASS system keeps up well, just thought id ask around
John Wood Nut Swinger
62psi is what mine is set at and it never budges on WOT runs. David Lott said to give 55psi a shot, it might make more power because the slower the fuel is flowing the less it will foam. I will give a true test on the dyno this weekend.
I like David, I met him at his shop in Houston a couple months ago and he knows his stuff on FASS systems.
This is very interesting. let us know how it goes..
David knows his stuff! I've stopped by and talked to him several times about various things. Good guy!
For fuel pressure, when I first installed mine I set it to 70 psi. Ran better but have not adjusted since injectors. need to mess with it some more now.
I've got mine at 55 but I want to install a gauge inside the cab because I saw where Tim mentioned about having to see what it does at WOT and I've not a friggin clue.
Mine is set at 60psi as well. On WOT it will briefly drop to the low 50's before coming right back up to pressure. By brief I mean like maybe 2 or 3 secs. I can read fuel PSI on my commander.
on my hot tunes it starts fine. on the econo, and tow tunes it is semi sluggish...
well my daily isn't really "hot" hahaha but you do know what my extreme file is like....
not the turbo. Have a boost leak and I think it is from the driver side plenum.. Didn't notice it before but one of the times I was installing my stealths I got a little too heavy and put a nice ding in the plenum. I don't think the boot covers it all the way... and really havn't felt like messing with it...
Oh yeah Scott. sorry for the :hijack:
1 - 20 of 20 Posts
