hmmm maybe thats why my trucks fuel mileage is a little low.... ill have to give that a try4
I haven't noted an MPG increase I'm getting 12 and I reckon this tank will be the same or less. But that is partially because prior to this mod I noted it cutting out and after this mod (not a mod I guess but don't know what to call it, service procedure I guess). While I noted this cutting out I was running some damn high boost trying to haul *** and get home. After this mod I was running a few 25+ psi runs to see if its fixed or if I had another issue going on. This mod was done the day after this started occuring and it cured it. I've also been idling a lot so I suspect that also hurts my mileage quite a bit. After this mod I too noticed a more pep in the step of the truck, in that I am guessing less fuel is required to maintain the same psi in the injectors.Just cleaned mine over the weekend. Immediately noticed a pick up in power on the "seat of the pants" meter. I'm hoping I will see an increase in fuel mileage from my, as of now, dismal 11mpg.
Winter fuel.Well maybe my problem is somewhere else then. The near 4.00 per gallon pricetag is good motivation to find the problem though.
Be a prudent idea to replace it I'd reckon. That or your tanks are damn pristine.I lost that screen years ago!
According to people I've talked to they said it drops easily 3-5 points. It is a combination of things however idle times/startup energy, etc. I was shocked at my first fill up of getting 12mpgs, I hope it returns in summer to about 15-16 or so.Yeah, I don't know if the winter blend is stronger there or if it just affects PSDs more, but I haven't ever noticed a drop of more than 1 mpg with winter fuel in any of my Dodges. Shouldn't these trucks be getting 14-15 mpg or better? That is just based on what I've read on here. I wouldn't think winter fuel would drop mpg's 3-4 points:dunno:
Yep, mine was just as bad as his. It isn't the tanks I would worry about but the big tanks at fuel stations. Those things are full of crap and the filters on the pumps don't do that great of a job...Be a prudent idea to replace it I'd reckon. That or your tanks are damn pristine.
F5TZ-9A214-A should be what you need.i lost my screen too. any way i could get another
Really damn I'm sorry about that. I'll attempt to relook for it.Pulled mine down and there is no screen. I guess the guy before me lost it.Thanks For the number.
Edit: That number is for a fitting or Adapter
