1 - 15 of 15 Posts
Looking to add a permanent fuel pressure gauge to my pickup.
What has worked well for those that have done it?
It's a 2005 f-250XL 6.0
I recently did the blue spring kit and it definitely runs better.
Thanks!
CTS3 with egt and universal 5v sensor add on
Thanks. I was just researching this one. The edge web site says the usual thru 07 f series. I've got an 08 E series and its not mentioned. . Should be the same?
Doesn't the 6.0 have factory egt? My 11 VW TDI does... Is think this would.
I am using the Dyno Tune square gauge and love it. Digital reading, small in size, Velcro mount where you want.
I like their dual gauge (fuel pressure and EGT), but $400 is a lot to spend!
Yeah the CTS3 works ony any OBD2 vehicle a d no the the 6.0 does not have a factory egt or fuel pressure indication
I use a Glowshift 3 in1 gauge. You also need to buy their adapters for the EGT probe and fuel bowl sender. I monitor EGT with the large gauge, FP and Boost with the smaller digital numeric gauges. I have it mounted using their pillar mount. It allows you to keep the the pillar mounted hand grip in place. The paint on the pillar mount sucks. It will fade to blue gray. I bought a rattle can and repainted mine. Gauge has been working fine for 3yrs or so.
BTL
Discussion Starter #12
These gauges are another option, and could be cut into the dash for a smooth look
I like my EDGE but I also like my pillar pod guages. I've been using ISSPROs for fuel and oil pressure for more than 5 years now. They're rock solid.
k
1 - 15 of 15 Posts
