I have a 2002 Ford F-250 7.3 power stroke… My fuel level gauge does not work what can I do to fix it?
Troubleshoot the problem
Most likely your sending unit isn’t working. It’s located in the fuel tank, you have to remove the bed or drop the tank to access it. Not saying this is 100% your problem but that’s where I’d suspect the issue is
Could be the wiring or the connector on the instrument cluster also
