I have a fuel leak on my 96 Ford. It drips out of a drain tube right in front of the oil pan. Does anyone know what this is from?
Look in front of the fuel filter housing and you should see a yellow lever. That drains the fuel in the fuel bowl and is attached to the drain tube you speak of. It might be partially open or it might be bad.
If it`s shut all the way (counter-clockwise) til it stops. It`s probably the drain valve 0-rings. Cheap fix. There are posts on this site that shows you how.
Infidel
If it`s not shut all the way (counter-clockwise) til it stops. It`s probably the drain valve 0-rings. Cheap fix. There are posts on this site that shows you how.
Yup, what this guy and the others have said.
Craig
