1 - 1 of 1 Posts
Have a 2005 with fuel getting into the oil. Pressure tested both sides and have a quick leak down on the passenger side. Pulled valve cover and could hear air hissing from the front injector. Pulled injector and oring look fine. Replaced orings with Ford and still leaks. Replaced o rings with D-tech set and still leaks. Put a used injector in that I had laying around and still leaks.
Is this a cracked casting? IT seems to be leaking at bout 4 o'clock on the injector.
1 - 1 of 1 Posts
