1 - 7 of 7 Posts
I got my oil analysis done and with all of the deletes there was 8% of fuel in the oil. What could cause this. Last test I did with the dpf still on was 2%.
Subscribed
High pressure fuel leak. Either at one of the injector lines or the HPF sensor. Either that or leaking injector.
im pretty sure the #8 injectors is bad i keep getting codes for it. ive had it to the dealer to 3 times and they wont replace the injector just the sleeve or some thing. im taking it in to the dealer next week. to tell them they need to replace it. would that be the reason why my mpg is in the ****ter
Maybe on the mpg. Prolly on the code and #8. How much idling do u do
Not much at all.
1 - 7 of 7 Posts
