Hey guys I'm not only brand new to this site but to diesels. I've worked on gas my whole life so I'm learning as I go. I have a 2006 f350 6.0 typical 6.0 problems:
*Over heating/coolant disappearing
-Replaced EGR valve/EGR cooler
*Would only drive 5 minutes before stalling then the famous no start when hot
-Replaced STC fitting
-Replaced dummy plugs and stand pipes
-Replaced oil cooler(while I was there)
-New ICP/IPR (got both for $60 from friend)
-Blue spring kit
When I was replacing the oil cooler I went to drain my oil, slid a 5 gallon bucket under the truck assuming 5 gallons was plenty of room. WRONG after spilling a gallon on my garage floor before getting another 5 gallon bucket in place, that bucket filled 3/4 of the way. The oil is extremely thin, all 8 gallons of it. The oil was only 1000 miles old. Before I started all this work I could hear air in my secondary fuel filter bowl. I cracked the top to see so much air that the fuel was foaming. So, I'm also replacing all the o-rings on my injectors. Only 1 injector had a somewhat suspect o-ring but the other looks threaded
any idea why it looks this way? What o-ring let's the fuel go by into the oil? Is there another way fuel is getting into my oil besides the injector?
-Blue spring kit
