1 - 12 of 12 Posts
Well my fuel gauge is stuck on full i dropped the tank thinking float was stuck but it wasnt i turned the key on moving the float up and down and the gauge still read full anyone have any info to help me before i buy another unit?
Other than ohming out the wiring harness going to the guage, and then ohming out the connector on the float assembly, and looking for a change when you move the float up and down, then id say the sending unit is bad. I don't know what the float is supposed to ohm out at, but you should be seeing a big change in reading
Mine always stuck on empty ha. Sounds like float is stuck mine does it every once in a wile
I was afraid the unit was bad lol got a salvage yard near by guess ill see if they have one i can try hopefully it fixes it
Make sure u have ground on the sending unit
Bump found the yellow/white wire split in 2 put it back together but still stuck on full....
well messing with it again today i got the gauge to work when moving the float around but as soon as its put back in the tank it goes back to reading full again...
also i just unplugged the terminals to see if maybe it will reset itself
Sounds like a connection problem, or a problem with the sender.....
Sounds like a nice problem to have haha but really have you checked the stepper motor behind the gauge?
1 - 12 of 12 Posts
