1 - 10 of 10 Posts
I usually fill up at a shell (I see best stats with their fuel) but I've been reading up on "76". Its a truck stop with renewable diesel. How would a. 7.3 run with that fuel? They claim to have >70 cetane.
7.3s will run on anything, I wouldn’t think twice about it. They’ll never miss a beat on trans fluid, waste motor oil, heating oil, kerosene, cooking oil (without glycerin) ULSD, high sulfur diesel, bio fuels, etc
And do not mix motor oil with veg oil.....
I wouldn't add any of the mentioned crap in my 7.3, while it may run with that chit in the fuel it's not a good idea. A good quality diesel fuel and a demulsifier type additive to help separate the water is all that ever goes in my tank. A pre-powerstroke IDI will digest anything with it's mechanical injectors, HEUI injectors cost more and they're harder to change. 76 will be fine, most important thing is a station that turns over enough fuel to keep it fresh and clean.
I go back and forth across the country. I have probably run every brand of fuel. some of has been bio because thats all that was available. Never noticed any difference. However do not use bio diesel if your truck will be sitting for months. I have been told by a few truck owners it grows algae
It’s all in how you filter it. My dad runs waste oil on his e350 and has been off and on for the past 120k miles. He filters it all down to 1 micron. He’s still on original injectors at 290,000 miles, it started right up at 0 F this past winter, they’re still very healthy
That's the thing, most guys don't have a way to filter it that fine. I used to run red farm fuel all the time in an old 6.9 IDI when it was still high sulfur and pump fuel was ulsd, night and day! Even the 7.3 psd would rather have high sulfur since that's what it was made to run on
Actually all diesel fuel grows algae just drop your tank and have a look that's why you do hutch mod to get rid of those stupid screens that plug up with algae
yeah but bio fuel is more prone to grow it. And I dont buy from places that I never see diesel trucks at.
Buy Biobor = bye algae. It’s really that simple
Once it leaves the refinery from its delivery method, then into a tank at the distributor, then to a truck to a station, and from those tanks to your truck you have no idea the filtration, tank conditions, or inspection methods and intervals before you swiped your card. Everything is probably ok, but it could be inferior. We test our fuel each delivery and each fueling. Aircraft are sumped daily and tested before each flight day, and with fuel consumption at 1.5 gpm per aircraft we turn A LOT of fuel. Even with all that we still use Biobor in the tanks we own. If all parameters are perfect, you can’t prevent temperature changes that lead to condensation, which leads to algae and microbial growth.
1 - 10 of 10 Posts
