(Off-road use only)
It hasn't even seen rain so no rust. I tried it and didn't see significant mpg gains towing so I decided not to use it. I was looking for close to double. I guess i was too optimistic.
$90
Fits: 2008-2010 Ford Powerstroke Diesel 6.4L
This is a DPF only Delete Pipe for your 2008-2010 Ford 6.4 Powerstroke Diesel. This is a direct fit for stock or all aftermarket DPF back exhaust kits. Built with 3/8 lazer cut flange and machine EGT bung for factory like fit and seal. Supplied with hardware to attach to factory exhaust and Built in OEM jig for exact fit. The one EGT sensor will be removed and put into this pipe, which has the fitting for the sensor. You will be supplied with bolts but you will NOT be supplied with a gasket. You can either buy a new one through Ford, or you can be careful and use your old one like we have done.
$90
