1 - 2 of 2 Posts
So I recently changed my shocks on my F250 to some Bilstein 5125s. I used the medium valving in the rear and the light valving in the front. The front I have dual shocks so I was told that I would need the softer valving up front. Now the problem seems to be that the front end bounces up and down anytime I hit a bump. So my question is are the shocks too soft or do I have another problem? The ride was stiff before but it was way better than the ride now.
Discussion Starter · #2 ·
Just called pro comp. they said my spring rate is 495 lbs per sq inch. So what shock calving should I run??
1 - 2 of 2 Posts
