Something else I found out and it is a hit or miss kinda thing, Some of these rigs 250-550 came thru with ball joints without grease from the factory. 250/350 are sealed, 450/550 have zerks. when i picked up my 450 second hand 50K miles the front end was a bit sloppy due to a bad ball joint. now 27k miles later I am replacing a bunch of stuff including the Steering box. Redhead is building a new unit nto cheap but the last one they did for me was outstanding.08 f350 with 62k. truck is in shop and needs-
drag links
1 tie rod
trac bar ball joint
shocks
steering stabilizer.
really? already? sounds expensive.
I also think i am going with a readhead gear box. I am also going to do ball joints, axel u joints and a track bar ball jointSomething else I found out and it is a hit or miss kinda thing, Some of these rigs 250-550 came thru with ball joints without grease from the factory. 250/350 are sealed, 450/550 have zerks. when i picked up my 450 second hand 50K miles the front end was a bit sloppy due to a bad ball joint. now 27k miles later I am replacing a bunch of stuff including the Steering box. Redhead is building a new unit nto cheap but the last one they did for me was outstanding.
