1 - 1 of 1 Posts
2000 7.3 runs OK no miss for about 20 minutes, Then engine lite comes on.it misses. Sometimes the engine lite goes back off miss stops and truck runs OK
Someone said a plug may have melted causing a short that indicates a problem, causes miss, then acts OK again.
Ford dealer said the code called for new injectors told him I think about his price to install an injector and drove about 25 miles lite went out enginestopped missing, drove anothe 5 miles the lite came bck on and the miss started again if an injector isn't working why would it then begin to work properly again causing the engine lite to go off and stop missing?
need help to learn about the possibility of an electrical connection or plug cause a proble rathe than injector that is not consistant
1 - 1 of 1 Posts
