So I’ve been collecting some waste fluids like atf, some used motor oils (10w30 and 15w40) I’ve probably got only 50 gallons but I want to start setting up the truck to run alternate fuels because I have a line on some veg that I haven’t gotten around to picking up yet.
So the question
Does anyone make a frame mounted aux tank?
The only tanks I see out there are in-bed tanks and I have a short bed so if I got a 100 or 150 gallon tank with the L shape I could put a toolbox on it but then I lose a lot of real estate for other stuff I don’t need like quads or parts or whatever. If you have a v3 setup with any kind of tank show some pics and let me know if you like it, what you would change etc let’s hear it all. I want to be able to travel some distance so 50 gallons under the truck would be minimum. I can carry spare fuel in 5 gallon cubes if on a trip or something but I only need 25 gallons tops for my weekly driving
I’ll take what I can get so my drawing board currently looks like this.....
Ultimate force centrifuge filling 5 gallon cubes for storage. 55 gallon drum coming soon
I’ll be dumping 5 gallon cubes or running the centrifuged oil directly into a 100-150 gallon l shaped tank in the bed where - heat exchanger heats oil and the v3 system will feed the 6literbeater
I’ll be burning these fuels like I said earlier....
Oil
ATF
WVO
WVO
That’s my current plan. I want a tank under the truck out of sight out of mind but I’m not terribly picky..... save $ is number 1 so I’ll be happy if I eliminate my 50$ fuel bill weekly average and drop the bill for the Florida trip I take at least once a year
So the question
Oil
ATF
WVO
WVO
